Can you post pics of inside and let us know how easy they are use?
It's pretty difficult to get decent pictures inside but I gave it a shot. As far as how easy it is to use - I've taken it off an on 4-5 times to practice and I can now do it in about two minutes.
See if this helps...
This pictures shows the front center lockdown clamp as well as the hood scoop vents. As you can see the driver side is open and the passenger side is closed (plug still in).
This picture shows the front left/right lockdown levers. It's nice not having to use the allen wrench any longer.
This pictures shows the clamps that lock down the left and right panels to the center section. There are two on each side. This one is obviously in the open position.
Same as above showing the clamp in the closed position.
This image shows the passenger side clamped down and ready to go.
This image shows the rear lock down brackets. This one is in the open position.
You also replace the bolts that fasten the sport bar with the custom pins shown in this picture so the sport bar can be easily slipped on and off.
Hopefully this helps...
