OK, don't kill me but my daughter wants to see a picture of a Pink Viper
Detlef
Northern Colorado
OK, don\'t kill me but my daughter wants to see a picture of a Pink Viper
Anyone ever see a Pink Viper and have a picture to share? My daughter keeps asking me if there is such a beast out there?
dennis
Germany, NRW, Ge
Re: OK, don\'t kill me but my daughter wants to see a picture of a Pink Viper
This is only a photoshop, but Barbie would still have fun...
AviP
New Canaan, CT
Sorry to hijack this thread, but seeing your signature I was curious. With all those mods, aren't your hp numbers too low? I thought a stock GTS made 400-430rwhp depending on the car & dyno.
Jerry Dobson
Lenexa, Kansas
Avi,
He has a 2001... Mild Cam. Also he has a 3.73 Gear. Put in a 307 and the Dyno will read higher.
malcoll
Jacksonville Florida
It's the clear corners... they drain 50 - 75 RWHP.
iispms
I think John looks right at home in a pink venom!! :)
D
Detlef
Northern Colorado
I am getting it redynoed at the end of this month and yes because of the gears, it's probably in the 430+ rwhp range. My previous 2002 totally stock GTS (not even smooth tubes) only got 400 rwhp on that same dyno. Maybe it's the dyno. Maybe I should put some ice on the intake manifold before my pull :)
Also check out this link showing the wide range of dyno results with Vipers.
D
Detlef
Northern Colorado
Guess I should have waited for the Graphite/Silver after all :2tu:
joe117
Maryland, USA
dennis,
That's Chuck driving that pink Viper, isn't it?
AviP
New Canaan, CT
So with all those mods, doesn't it make more sense to stick with stock 3.07 since it equates to more hp with less wheelspin and better 1/4 mile numbers? Won't it make that power more managable for the street?
Kiaser
Ok, you saw a pink Viper, now let's see your daughter!
genXgts
windsor, ontario, canada
Don't start the gear debate Avi as it's a losing battle.
I've raced the same GTS in my GTS that had a gear and then went back to OEM and there is next to no difference in acceleration. We've raced dozens of times with each gear.
Seat of the pants will tell you the car is quicker but it does not make the car quicker in my book, so your right.
It sure opens a can'o'worms though!
joe117
Maryland, USA
If the rear ratio changes the dyno it's because of the way the dyno measures torque.
There really isn't any change in RW horsepower.
Snakester
Morgan Hill
The dyno numbers seem a bit low, but they are not too far off.
I got 435RWHP/460RWTQ N/A with tubes/filters, airbox, roller rockers, HF Cats, Corsa Cat back, VEC-1, and 3.55 gears.
As long as your Viper isn't pink, then you are doing great! :2tu:
D
Detlef
Northern Colorado
I also live at 5000 feet which takes away 15-20% power to begin with, so the gears actually make the car a lot more responsive for street driving and the little autocrossing I do. Never a wheel spin problem unless I purposefully try ;)
D
Detlef
Northern Colorado
That's a photoshopped one. Post a real one and I'll post a pic of my daughter!
D
Detlef
Northern Colorado
I finally redynoed today and put down 446 RWHP and 478 RWTQ, adjusted by 3% for the 3.73 gears. A Supra did 780 RWHP with twin-turbos and nitrous. That little I6 is amazingly stout.
viperkim
