Once again Arrow vs T&D's
Status
Not open for further replies.
SmokinV10
Houston, TX
Once again Arrow vs T&D\'s
Ive done some searching on this subject and most of the threads had some repetitive info, but never quite answered the question. Which is really better? T&D's at twice the price, or Arrow? I have heard of crowers dropping valves because they arnet shaft mounted. Arrows are shaft mounted by the pair per cylinder. And T&D's are the most robust but at a substantial cost increase. So.....
1) I have heard of some members dropping valves. How is this possible with arrows if they are shaft mounted in pairs? If they had a problem does anyone know if it is fixed?
2) T&D's are shaft mounted rockers as well. Both are billet. So whats the difference?
3) What length pushrod should I use with a 99 GTS with a June build date? With arrows? With T&D's.
Thanks everyone in advance for your help on this subject
King GTS
Houston, Tx.
Re: Once again Arrow vs T&D\'s
T&D's!!! I had Arrows & I ended up on the side of the road, broken down, in the heat, waiting for a tow truck!
I had a good buddy, not 1 month ago, that had arrows and they literally broke right in front of me in a parking lot! All of the sudden his engine sounded like someone threw a dumbbell in it - just like mine did. Arrows totally ****! And their cheap! I would never reccomend them!
Chuck 98 RT/10
tampa, fl USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Fred(DrivingSchool)Kinder:
The Le Mans winning motors had T&D's!
<HR></BLOCKQUOTE>
That's all the proof I need.
9 seconds
Texas
I've never even heard of T&D problems but I've seen a couple of Arrow failures. It's your money, though.
Fort Lauderdale, Florida.
Here's a little info I pulled up from one of my prior posts. Hope this helps....
The stock Viper rocker arms are a stamped piece of steel to change the up/down movement into valve opening and closing. The ratio between the pushrod movement and the amount of valve opening is 1.6:1. Hence, if the pushrod were to move one inch the valve stem would move 1.6 inches. T&Ds (roller rockers) use needle bearings to reduce friction, and tip rollers to eliminate valve guide side loading. These expensive forgings make accurate ratios and thus more accurate valve timing. The available ratio from utilizing the T&Ds are 1.6:1 or 1.7:1. The difference between 1.6 and 1.7 is .032" more lift. And BTW. Shaft rockers are far superior to stud mounted rocker arms, they provide better rocker arm geometry and make for a more rigid valve train.
Overview:
Apparently, the Arrow's (stud mounted rockers with a single common shaft) have been revised from their earlier production pieces, so I cannot rule-out their structural integrity without more data on their current status. You may want to gather more feedback on them from other's who are currently using the new and improved parts. Their price appears attractive, but shaft mounted rockers (T&Ds) WILL provide for the most ridged valvetrain. Suffice to say, if indeed the Arrows are improved from their prior status, may be utilized for lower horsepower applications unless proven otherwise.
Never assume replacing the rocker arms requires a certain length pushrod. Have a trained mechanic check valve-geometry to make certain the geometry is "on target." Proper valvetrain geometry is a crucial part of your engines performance. Improper geometry will also lead to valve guide failure in no time. Now, which pushrods to use? The stock ones! Unless your utilizing a higher lift cam with higher spring rates, (I wouldn't worry about pushrod deflection or acoustics) guide plates etc..., the stock pushrods provide a weak-link in the event of valve-float, ESPECIALLY on a street car application with street tires for the weekend warrior
. With the replacement of rocker arms, you may use used pushrods under two conditions: Check pushrods for straightness by rolling on a flat surface. If you suspect a pushrod is bent, check it with a 0.008-in feeler gauge. If the gauge fits, don't try to straighten the pushrod, replace it! With the installation of new rocker arms, flip the pushrods end for end -- wear at the rocker arm end extends much father around the rocker arm then does the lifter end due to the higher angular movement of the rocker arm. This will have the effect similar to installing new pushrods.
Best of Luck!
Doug Levin
SmokinV10
Houston, TX
I talked to the guys at Arrow today. They informed me that they have fixed the problem. They said it was a bad set of adjusters that went out. When the adjusters that supplied the pre-load failed so did the assembly. They also said that they have many sets out there with the improvements that are doing fine. Anyone have feedback?
Tom Welch
Blairsville, Georgia
I love em, and who can you trust more to cover any damages from product problems than the company who warranties your Viper engine?
What more is there to discuss on this subject?
Tom
Http://btrviper.com
SmokinV10
Houston, TX
See I was almost convinced, but this is the kind of response which makes me scared to come back a month from now and post "you guys told me so". But then a few reputable tuners have recommended this as a good product.....supposedly fixed...hmmm
Bad_Byte
Corpus Christi Tx
IMHO... It's easy to say some product *****, but to say why or what is deficient is a whole different matter. I have been down this road before.
Installed Arrow's a few thousand miles ago and no problems to report sir! Just ensure you use loctite on the adjusters and the proper pushrod length. It's not magic.
Status
JKGiant
