Paxton and Vibration
rhallman
I have had a slight vibration at around 2000-2400 RPM since having the Paxton installed. Ive read some other emails regarding a Damper. Is this the fix, or do I have another issue? Or is this nornal for a Paxton SC install?
Thanks...Rich
Bobpantax
Miami
I have had my Paxton since 19 miles on the clock. No vibration. I notice that you have the Woodhouse mounts. Were they put in at the same time? If so, the vibration could be from them. There is a bit more for awhile until they settle in and then it fades. If it is from the mounts, that is normal. It should not be from the Paxton.
rhallman
rhallman
I had the mounts on for a few years with no issues before the paxton. Thanks..
rhallman
rhallman
Feels like its coming from the engine. Didn't have the vibration until he Paxton was installed. I saw Dan Cragin is back, so I'll email him as well to see what I should check. Thanks.....
Viper X
Damper is what I'd suspect too. Was it pinned in during the install?
I ended up having to buy the aftermarket ATI damper. No issues since and over 40K miles.
Dan
SKY1960
