How to post a picture once you have a photo in your gallery:
1. Go to your gallery and LEFT CLICK on the thumbnail of the picture you wish to post. The resulting screen will show a medium-sized image of the thumbnail you clicked on.
2. RIGHT CLICK on the medium-sized image and select “Properties” from the dropdown menu that appears. A popup window entitle “Properties" will then appear.
3. On the Properties popup window,
a. DOUBLE LEFT CLICK (to select) the “Address (URL):” information, which will highlight the selected information. In your case Michael, that would be this Address/URL:
http://gallery.viperclub.org/data/529/8605Viper_0421-med.jpg
assuming you selected the second picture in your gallery; and then…
b. RIGHT CLICK on the now-highlighted Address/URL and select “Copy” from the dropdown window the appears.
4. Go to the tread where you want to post your picture and RIGHT CLICK in the comment window and then select “Paste” from the dropdown menu which appears, which will paste the Address/URL in the comment window:
5. Finally, and this is the tricky part
a. type before (on the same line, no spaces) the Address/URL this:
[image]
and type after (on the same line, no spaces) the Address/URL this:
[/image]
and then simply submit your comments for posting and you should have a picture.
Try it.
