Posted for sale on the local board, flywheel, brake pads, mufflers, wheels, tires
Supr_Vlln
Los Angeles, CA
I just posted a bunch of stuff for sale on the local board. Prefer a local sale.
CCW C12 Corsair wheels mounted with Kuhmo Ecsta V700 track tires
http://socalviper.com/forum/index.php?topic=1466.0
CCW 18x12 C12 wheels with M&H Drag Radials
[URL]http://socalviper.com/forum/index.php?topic=1467.0
[/URL]M&H Drag Radial track tires - new, never used
http://socalviper.com/forum/index.php?topic=1468.0
Orange Silicone Duct Hose for brakes, intake, etc.
http://socalviper.com/forum/index.php?topic=1469.0
Performance Friction 01 compound track pads
http://socalviper.com/forum/index.php?topic=1470.0
Brake Man #3 compound brake pads
http://socalviper.com/forum/index.php?topic=1471.0
Lightweight flywheel chromoly
http://socalviper.com/forum/index.php?topic=1472.0
Mopar/Borla cat-back mufflers for Gen 3/4
http://socalviper.com/forum/index.php?topic=1473.0
cweaver22
SoCal
i'm interested but where can i get the tips from? only thing i could find by either mopar or borla was the entire system? why do you have just the mufflers? what happened to the rest of the system? do you have the clamps to hold everything together?
Supr_Vlln
Los Angeles, CA
I bought the system new a while back and it came with clamps and tips. I was doing some exhaust system experiments at the time and ended up using the tips with a different set of mufflers. I should be able to dig up the clamps, but I would recommend welding the tips on and a tack weld and clamp to the cats. Without the crossover tubes, the pieces have a tendency to move around if you are using nothing but clamps.
As for where you can get tips...
1. You can check with Dan at DC Performance. He may have some factory tips from Gen 4s that you can buy. But bear in mind these will look just like factory tips no shiny bling. You could modify the gen 4 tips to allow welding on of a more polished custom tip.
2. Also try checking with Belanger they may be able to just sell you the tips. You may need a 2.5" to 3" adapter.
3. Have an exhaust shop make you a turn out pipe and then weld on whatever tip you want. DC Performance also has a fabricator that can do this for you.
Viper123456
