Preserving Rubber Seals
crackleking
What product works best to keep the rubber seals around the doors and other areas to keep them from cracking and staying pliable?
Bugman Jeff
Wisconsin
I second silicone based products. Do NOT use anything petroleum based. If it's got "Petroleum distillates" listed on the bottle, it will cause the rubber to dry out over time. The same products you use on your interior can be used on seals too.
Matt M PA
Langhorne, PA USA
At the risk of being argumentative...I would advise against silicone products. The best for preserving rubber and vinyl is 303. It's recommended by manufacturers. Do a search for 303 Aerospace Protectant.
DrumrBoy
GA
Does it mix well with Mountain Dew and Jack Daniels? If so I'm in!
justingeer82
silicone is natural rubbers best friend. you can use tire shine on a rag and wipe tight spots. do not get that stuff around your seats.....PERIOD!
jpolen21
