quick question: drive shaft removal
snampro
Dayton, OH
I have to drain the trans before pulling the drive shaft out the back, right? otherwise it will drain itself?
Joseph Dell
Atlanta, GA 30338
Nope. just pull it out. if you remove the trans, then put a rubber glove over the end so you don't lose any fluid.
not to worry... easy as pie!
JD
CROM
Fairfax, VA
What JD said.
Took me about 5 mins to remove...slides right out and right back in.
snampro
Dayton, OH
sweet, I removed it earlier to change the u-joints, but I drained the fluid because I needed to change it anyway.
thanks for the help.
viperkim
