Radiator Fan "sensor"
AlvaSpeed
Panama
Where is the sensor that turns the radiator fan on when the car reaches operating temperature?
1998 GTS
A
AlvaSpeed
Panama
What I want to know is what activates thye radiator fan and where it is located.
G
grcforce327
Guest
Temp sensor talks to the ecu,ecu talks to the fan relay..... Fan Party!:dunno:
Tom F&L GoR
Wappingers Falls
On a Gen 1 there are three temperature sensors screwed into the block or thermostat housing. The sensors are resistors or thermistors and change resistance with changing temperature. One is the feed for the temp guage, another for the red idiot light, and the third for the ECU. The ECU reads the signal and determines when or if the turn the fan on.
Gen 2 has the thermostat in a different location, I know. I think this gives you the answer, though.
G
grcforce327
Guest
Tom,the fan relay is not your friend anymore:D!
If you are chasing a fan issue,jump the fan at the plug and see if it indeed works,then go to the relay next,them go to the temp sensor!:2tu:
A
AlvaSpeed
Panama
O.K
But where are these sensors located.
The fan is not turning on automatically.
We checked the fan and it is o.k.
GreatWhiteKAC
