Rear Facia Adjustment?
Rare1
Sweden
Can anyone tell me how I can adjust the rear facia/bumper?
I need to have the top part adjusted inwards, toward the trunk!
As it is today it seems to be to far out, as there is a bad looking "line" whith poor painting and scratches being shown. If I can adjust it just a little the rear will look perfect!
Pleas help!
Mikael
There is relatively little adjustment that can be done with the rear fascia. You need to remove the lower rear fenderwell panels on each side to access the 15mm nuts at the back of the frame rails. This will allow some vertical and horizontal movement of the fiberglas bumper support, but proper adjustment requires another set of hands and eyes.
It sounds to me as if your fascia has pulled away from the bumper support, though. It is retained across the top by nylon push-fasteners. If you have an RT/10, you should be able to see them under the trunk lid. The GTS fasteners are obstructed by the taillight panel.
