Removeing rear sub panel
Omaha NE.
You will need to pull the seats and remove the rear bulkhead panel that covers everything. Not hard just go slow. The sub and box are right there when you get the panel off and you will see it is straight forward from there. What are you putting in it's place? there is very limited room behind the panels.
Dustman
Sweet Home Alabama
Are you saying you will have to 'remove' the seats in order to remove the panel :omg: or just "pull" them forward ?! :cool:
Omaha NE.
It makes it much easier to just un bolt them and get them out of the way. You will risk scratching or tearing them otherwise, plus it is quicker in the end.
DMan
Maryland
Wow.
I'm interested to hear what you & others are replacing the stocker with. I'm going to do seat lowering kits as a little project & if the seats come out, I really might as well do a little sub upgrade if it's not too big a deal once the seats are out anyway.
VAViper
Leesburg,VA
Any other steps necessary for the vert?
08viperviolet
coral gables FL
Thanks Mark,
I'm putting in a JL 6w0. In eariler post it fits in and is a very good speaker for the size and place. Just replaced door and dash speakers with new diamond components. Mark one other question is their any special in removing 08 seats or just 4 bolts.
Thanks for the help
Joshua
Omaha NE.
Thanks Mark,
Thanks for the help
Joshua
There are electrical connectors under the seat that need to be disconnected before you lift out the seats. It would not be a bad idea to disconnect the battery while doing these things either as the modules are sensitive.
wallbanger
Sounds like one of those projects that u think is gonna take an hour but takes all day by the time u're finished....
Nader
New York
Another good thread. I am waiting in anticipation whether there is an option to replace the marginal stock sub.
zoomie
Owings Mills, MD, USA
Might not hurt to take photos before, during, after.. and share with others interested.
Good info all around..
Qdog
