Replacement ACR ring options
So I started trying to search and sift through old threads, but not sure I could come up with and condense the info I was looking for. What I'm wondering is what are all the options available for replacing just the rings on a set of two piece rotors. I currently have a set of StopTech two piece rotors (black hats, not factory ACR ones) and had the dreaded emergency brake pad dragging issue that scored up one rotor a bit. I'm looking into refinishing it since only one side of one rotor is bad, but am not having the best luck yet. That being said, what are all the options for replacement rings? So far about all I can come up with is the StopTech factory stuff and maybe some Brembo replacements as well. Sounds like Euroteck doesn't sell just rings, so that one is out of the picture. Are there any other manufacturers of rings that will fit the StopTech hats or am I just hosed if I have to end up getting a new one? Along those lines, does anyone sell individual rotors as opposed to pairs?
