Hi Everyone,
We're pleased to announce that our wing is ready and going into production. We should have complete sets in stock within two weeks.
Introductory price is $699.95
Our adjustable rear wing for the GTS gives you an opportunity to increase rear wheel grip and adjust the car balance in high speed corners. In addition to providing a greater level of confidence in the car's ability to remain stable, you will also see a decrease in lap times. Improvements of over 1 second per lap can be expected due to the ability of the car to maintain higher cornering speeds and heavier throttle application on corner exit.
On a car without aerodynamic aids that is balanced for medium speed corners, chassis dynamics dictate that the vehicle will tend to oversteer in higher speed corners. The slower the cornering speed, the more the vehicle will tend to understeer at the tires limit of adhesion.
An adjustable wing is a tool that you can use to vastly improve the handling of your car. Use mechanical adjustments, such as wheel toe and ride height, to properly tune the car for low and medium speed corners. As cornering speed increases, instead of getting oversteer, which would occur naturally, you can maintain the balance of the car because of the increased aerodynamic downforce the wing provides.
Our wing design provides low drag and is adjustable from low to high downforce settings. Typical angle of attack ranges from 0 to 5 degrees. makes a great combination with our front duct kit which reduces front end lift and drag.
Wing Website Page at RoeRacing.com
