ROEcated and TATORized
LIVIPER
New York
Chuck Tator just installed a Roe blower!! (A perfect job as always!! Thanks Chuck!!!)I love it. I am running 5 lbs for now. I think I will definitely move up to the 8lbs next year. My first impression is that I was very surprise how smooth and even the power comes on. I’ve never driven a blown car before, but I think I expected to feel a jolt when the boost kicks in. Not so. It’s very smooth and even.
One question for you 8lbs guys. If you did run the 5lbs prior, is there a big difference at 8 lbs? Is there alot more power? Is it still smooth?
Cudaman
USA
It saves a lot of weight going to the 8 LB pulley...it is a smaller pulley. :D
Cudaman :usa:
Joe Dozzo
Golden, CO
At 6000+ ft in altitude, going from stock to the Roe SC with a 5psi pulley was a BIG kick in the pants!
Going from 5 psi pulley to 8psi was ok, but not a huge difference in driving-around perception. Maybe at the dragstrip...
Either 5 or 8 psi pulley and the car is very civilized! No noticable difference in idle / heat, still smooth as silk, either way!
DrewViperz
