RTScott
Just trying to remove to clear out some road debris from these areas.
Started on the driver-side. Removed the 6 bolts on top and the 4 on the bottom (that I could see/find). I used a small flat head screw driver (the end wrapped in cloth) to pop the top plastic caps off, to not scratch the surounding surface.
It doesn't want to release, so I can assume there is another bolt/fastener somewhere that I cannot immediately see. Can someone assist? Also, is there a standard tool used to remove the plastic covers? And, is there an easier way. I intend to blow out and vacuum the inside of the sill/side spoiler cover area.
Thanks in advance.
v/r
Scott
Thanks in advance.
v/r
Scott
