Running rich
Diablo Joe
Lakeland,Fl
Ok as some of you know Ive been battling a hot side sill problem.I realized that when I zero out my VEC1,the car still runs rich(right blue light) Now,Ive started to lean it out a bit on the low and high end and the side sills are cool.What could have caused my car to run overly rich? When I first installed the VEC1 I tuned it perfectly.It required that I richen it at low throttle input and lean it out at WOT.Something has changed that setting drastically.Could it be a faulty O2? I dont want to set it lean and then have the car revert back to the way it was and go REALLY lean as I might not notice it.
Joe
LTHL VPR
Did you reset your computer when you installed the VEC 1?
The computer does go through a learning phase over time, especially after it has been reset (disconnected connectors, removed ground wire, etc..). It is possible that your computer was going through the big learning curve and adapting. How many mile have you put on it since the VEC1 was installed?
-W
KenH
Portland, OR, USA
Do you have a MIL light on for some reason? If so, that will generally cause the car to run on the rich side since it goes into a self protection mode.
--- Ken
D
Diablo Joe
Lakeland,Fl
Ive probably put at least 500 miles on the car since resetting the ECU.You think I should reset it again?
Joe
D
Diablo Joe
Lakeland,Fl
Whats an MIL light? Like a Check engine light? If so,no lights were on.While were on the subject of lights,I did notice there is a light for a Low Tire.How does it know this?
Joe
KenH
Portland, OR, USA
MIL stands for 'Malfunction Indicator Light' and is the new official name for the check engine light.
I don't think there's a light for low tire pressure. Are you sure you weren't sitting in your NSX
--- Ken
MichaelP
Orlando FL and Seneca Lake NY
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by TTBADBOY:
Joe
<HR></BLOCKQUOTE>
Hunh, Low Tire light?
D
Diablo Joe
Lakeland,Fl
Yes,look real close at your light display box and you can see a light for low tire.Ill take a pic of it tomorrow and post it.
Joe
D
Diablo Joe
Lakeland,Fl
Heres the pic.You can barely make it out but if you look at your own car,you'll see it.
Its beneath the door ajar light
Joe
Jerry Dobson
Lenexa, Kansas
TTBADBoy,
The low tire pressure is trasmitted from pressure sensors within the rim. But our cars don't have this. Wild that you found that. Nice place to put a signal light if you put an aftermarket system on the car.
The ECU learns as you drive. This could take 300-500 miles. You most likely disconnected the battery to install the VEC, have you put many miles on it since the upgrade?
DrewViperz
