small rubber piece on bottom of starter
martyb
IL
Can someone tell me what the small 1" rubber piece on the bottom of the start is? I knocked it off, and the plastic clips that hold it in seem broken. Do I need it and if so, can it be purchased??
Thanks all,
martyb
M
martyb
IL
nobody? I have to think someones run across this before.
BOTTLEFED
Pocatello,ID
I have seen them on other starters. I'm not exactly sure what it is though. It may be an access to a screw or wire or something.
I haven't had a starter apart in almost 10yrs ;)
carguy07
Cuyahoga Falls, OH, USA
Are you talking about the little black thing? I think that is just a moisture drain tube.
I doubt it means much if you do not drive in the rain (more to keep water from splashing in the drain hole than out).
M
martyb
IL
yup, thats the piece I am referring to. I suspected it was a drain of somesort, just didn't know if I could drive the car in the rain without it. I may just put a dab of RTV on it, put in back on the starter and call it a day.
RTTTTed
Think of that rubber tube as a splash shield more than a drain.
Ted
M
martyb
IL
Thanks Chuck!! It seems to have a small plastic clip to hold it in place, which broke on my part. I ended up putting a dab of RTV on it and re-installing. Next time I am under the car, well have to see if it worked! If not, can that part be purchased, or would I need to buy an entire starter?
SKY1960
