Someone who has an ACR and can measure. Canards
Blockbuster
Sweden
I bought Canards from vender and looking after info and I found this picture from another tread and need Someone who has an ACR and can measure. The distance between the lower Canard and splitter.
Thank you very much:2tu::usa:
Lee00blacksilverGTS
Severna Park, Maryland
From left to right 3", 3 1/2", 5 1/2" I did it from the top outside edge of the bottom splitter to the underneath surface of the canard. You look like you were pointing at bolt holes but as mine is OEM and yours aftermarket I would not use the holes to measure the actual location. There may be serious variances from car to car also.
redtanrt10
Dana Point CA
Blockbuster,
I bought the set from Prefix and they gave me an install manual and paper template's (templates are long gone). Here's some info from the manual that should help;
- "Upper rearward edge of the dive plane to facia corner is appprox. 11 1/8"
- "Verify front edge of the dive plane is parallel to facia feature line"
- "Drill out 3 holes using 5/16 drill bit"
- Place "O" ring onto rivet, washer to rear and proceed to rivet in place"
You know how it should look, so just make sure the botton is parallell to the "rise" on the facia and that the back edge is 11 1/8" from the top of the facia.
Also, we used nylocks vs. rivets, those rivets can/will come loose.
Good luck, Mike
B
Blockbuster
Sweden
Thanks and here more info to other Viper brother :)
