Sparkplugs with Nitrous
FATHERFORD
Texas
What plugs are you nitrous guys using? I plan on doing a 250rwhp pill with 116 in the dedicated fuel cell, so I would need 2 steps colder.
Thanks,
Justin
my guess was 2 steps colder till ya said the 116 fuel. im not sure how thats gonna effect it.
99 R/T 10
Enterprise, AL USA
I run a 2 step colder plug and LOVE it! Still has an extended reach for good cold starts. Champion RC10ECC is the only way to go :2tu:. I think Daniel Lesser (Viper Specialty ) sells the plug for $70 a set, but PM him to be sure.
99 R/T 10
Enterprise, AL USA
Not sure Phil, maybe. I would think if he is using 116, then he could probably get away with a one step colder plug. He'll need to tune it anyway and as long as his A/F is in the 11's with no detonation, he should be fine either way. But he asked for a 2 step colder plug, I like them Champions :2tu:
F
FATHERFORD
Texas
I'll have a wide banned hooked up and street tune the car, along with pulling the plugs to check for even distribution between all cylinders.
F
FATHERFORD
Texas
Well here is what I found out calling around.
Autolite 1800-890-2075
985 is the oe plug
AR3924 1 step colder
AR3923 2 steps colder
Champion 1-800-325-8886
RC10ECC/RC10918 discontinued
Now here is where it gets interesting. The federal mogul champion tech told me the RC10868 marine plug "should" be the same plug as the ECC/918.
Perhaps a viper vender knows something of this?
EDIT: Well apprently the 868 is a lawn mower plug? I need to call tech back and see what's up.
Dan Cragin
LA, CA
NGK4291 works great for this application. We have them in stock. 310-841-6996.
Dan
F
FATHERFORD
Texas
Thanks for explanation on why the shorter range plugs work best in this situation DC performance.
Just ordered me 30 NGK's for a tad over $70 shipped.
99 R/T 10
Enterprise, AL USA
I would like to hear this explaination. I've heard of "colder range" plugs and "Shorter and longer reach" plugs, but I've never heard of shorter range plugs?! :confused::confused:
The RC10ECC is a stock reach plug with a 2-step colder range, which is why it works so well. Good cold starts with the plus of being a colder plug. Other makes of colder plugs have a MUCH shorter reach and cold engine run proporties **** bad :(. I would like either Dan Cragin and/or Daniel Lesser speak to this and if I am wrong, please correct me.
F
FATHERFORD
Texas
meant reach not range... Brain fart!
I'm sure he could get more into then I could. Spark plug lingo isn't my cup of tea.
Are the RC10ECC a better plug? Probally. They are also hard to find and $11 a piece. Where as the NGK is common and $2.40 a piece and will work "just fine" according to Dan.
KC
Tucson, AZ
I bought the NGK 4291 (ZFR6F-11) to use with nitrous The gap is .40 should I set the gap at .35
thanks
VinhyVegas
