Tensioner Removal
Purdue_Boiler_Viper
Indy
I'm trying to remove the tensioner on my 01 GTS. No problem on getting the pulley off, but I can't see how to remove the tensioner. Anybody know where it bolts on? From the bottom? How many bolts?
Thanks.
BOTTLEFED
Pocatello,ID
IIRC, its just got one 15mm bolt holding it on with a nut on the back
it shouldn't be that hard to see with the pulley off
P
Purdue_Boiler_Viper
Indy
Thanks guys. Found it, but not without the help of a mirror and flashlight. Two more questions for this crowd. One, my pulley wobbles around on the tensioner arm until you bolt it on. I assume that is normal, but I'd like to know if this is a sign of wear. The car only has 10k miles.
Two, anyone know what is normal for the torque of the tensioner? You see threads where a weak tensioner is mentioned, but not defined. I measured my tensioner with a torque wrench on the vice, and found that it takes about 20 ft lbs to move it through its range. I wonder if that is normal.
BOTTLEFED
Pocatello,ID
If it wobbles then the bearings are shot. My new one did not wobble.
Call Chuck, he can get you a new one cheap.
P
Purdue_Boiler_Viper
Indy
Sorry, was not clear enough on my description. The bearings on the pulley seem to be OK. No play, grating, etc. But, there is a lot of slop around the bolt. But, once the pulley is bolted down onto the arm, there is no obvious wobble. I think this is normal.
xeng yang
