Transmission difference between 2008 and 2013?
Blockbuster
Sweden
transmission difference between 2008 and 2013?
Are there any advantages to changing gearbox to 2013 from 2008?
(2013 Dodge Viper SRT10 TR6060 6-Speed Transmission)
Steve M
Dayton, OH
The gear ratios are different...you'd want to make sure you were running a 3.55 or steeper gear in the rear to compensate.
B
Blockbuster
Sweden
I was out driving and it begin to sound and look turned out that it was the gearbox that sounded like a metal lathe. I disengaged and then not working the gearbox. Repair or buy new?
SRT09
Edmonton
There is also a differenece between the 08-09 and the 10 gear ratios in 5th and 6th
Steve M
Dayton, OH
My initial reaction is to say repair, but seeing that you are in Sweden, I'm not sure how feasible that is. There are a few places here in the States where you can easily repair it, and add upgrades if wanted (like a taller 5th and 6th gear cluster).
Regardless, unless you want to change the rear gear ratio at the same time, I'd stay with the '08-'10 version of the 6060.
Qdog
