trouble code 0118
PatentLaw
Sugar Land, Texas
A bad connection at the sensor (engine coolant sensor)
An open in the ground circuit between the sensor and the PCM
A short in the voltage feed between the sensor and the PCM
A bad PCM (less likely)
A bad engine coolant sensor
Hope that helps.
Viper Wizard
South Salem, NY USA
Hope that helps.
Yes, check all of these!
For the most frequent failures for that system that I've come across, it has been the temp sensor. I keep a half a dozen of them in stock and if you need one or just want to talk about that code, 914-763-3136. :cool:
PatentLaw
Sugar Land, Texas
I respectfully defer to a man with more knowledge than I have.
In brief....what he said. :D
xeng yang
