Viper Amp Question
LarryJ
Akron, Oh USA
Does anyone know if the amp on my 99 rt powers the door speakers as well as the "sub". I am replacing all the speakers and i am trying to figure out if i will need a new amp or not. any suggestions from you audio guys would be greatly appreciated. also would a new head unit make any difference in wether or not i need a better amp.
shifter
Novi, Michigan
LarryJ,
Diamond Audio are decent speakers, you'll enjoy them. Are they component speakers like the stock ones (seperate tweeter) or the coax type? What is their power rating? If it's only 45 watts RMS, then you should be O.K. with the stock amp. Aftermarket amps make a big difference in sound quality. My logic is if you are going to change the speakers, why not change the amp at the same time and enjoy great sound instead of good sound?
The amp I used is one of many that will work fine. Actually, you might be better off with an Alpine amp, they make one very similar to the stock one but with more power, and can actually fit in the stock location. If not, under the driver or passenger seat is a good location and running wires to it is simple.
I ran all new wires because I wanted to maximize power and minimize noise. Also, I didn't want to cut any stock wires, so since I had to run 1 new one (the remote turn on wire) I figured I might as well run all new ones. I also ran 12 gage speaker wire. The stock wires will work, but not well with an aftermarket amp. You will also need RCA's going to the amp. You can use a line level converter and tap into the stock wires, but noise is an issue, and you have to cut into the stock wires. You also have to consider that the stock speaker wires are incredibly small. 16 gage is the minimum I would recommend for car audio system. The voltage drop of anything smaller is significant.
However, if you are looking for a small but noticeable improvement in sound quality, stick with your plan of just changing speakers. If you go beyond that, you might as well go all the way.
L
LarryJ
Akron, Oh USA
thanks shifter, i read the thread and i actually have the same jl audio 6" sub you talk about with diamond speakers for the doors(probably not as good as mb quartz but a little cheaper). i quess i'll look into that jl amp ...do you know where i can get the best price? also if the stick amp pushes all the speakers why would i need to have all new wires run(basically i am trying to make it as easy as possible on whoever will be working on my car). thanks for your input
Mpcc
