Wanted - 1996 Black Radio Bezel
Andrew/USPWR
W. Palm Beach
What are you calling the radio bezel? Is it the entire piece that goes around the lighter and AC?
2000 GTS Steel Grey
6 piston Baer claws up front, Front brakes in back, Quaife differential, GKH half shafts,
Alloy fly wheel, Short throw shifter, Polished aluminum intakes, K&N air filters,
Optima battery, Sterling silver ignition key, ACR 5 point harnesses.
Achilles99
Atlanta, GA
I think it's the black rectangle that goes around the radio faceplate, under the piece that goes around the lighter and AC. When I had an aftermarket headunit installed, the aftermarket bezel didn't fill in the "gap" around the faceplate. I just used the stock bezel, and it covered the gap fine.
For some reason, the radio mounting is set deeper into the dash than other 1 DIN radios...
T
THOR
TX / AZ / CA
Andrew - Yes, by "radio bezel", I am referring to the center console plate the wraps up and around the radio and AC controls, and down and around the gear shift and ashtray. Any assistance in locating one of these would be greatly appreciated.
VIPER BAZ UK
ENGLAND
About 3 weeks ago maybe less ..
Just done a dash change to black from grey just need glocebox door now.......
T
THOR
TX / AZ / CA
Wow, that is so surprising. Chuck says he has none. Which dash p/n did you get? I thought the glove box door came with the, but maybe it depends on which D/C p/n you bought. (?)
How was the removal/install? Easy? Any unexpected problems?
Do you have any pics you can post? :)
VIPER BAZ UK
ENGLAND
The dash did not come from Chuck i already had that just needed the bits to go with it..
As you can see i need the bit to go on the drivers door as well as glovebox door.
Had no probs in fitting the dash alot easier than i thought about six screws then it just pulls off.....
Tomer
Los Altos, CA
THOR, I have one, I think I might have gotten the last one from Chuck...
Let me inspect the condition of my existing one in the car, and I will double check the part number, but I am sure it is what you are looking for...
Tomer
dennis
Germany, NRW, Ge
Your steering-wheel looks like one I had as a kind of joystick for computer-games...
venomblue550
it's in really good shape, right out from a 96 RT, NO borken clips back there....PM me and let me know....
VIPER BAZ UK
ENGLAND
Dont suppose you have a black glovebox door as well and the drivers side black door bezell??????
Razorwire
