Water and oil temperature sensor locations
SketchyPete
Concord NC
Hey everyone, I was wanting to know if anybody knows where the oil and water temperature sensors are located on an 8.4? Thanks
I believe the water temp is in the thermostat housing at the top of the engine. It is on the 8.3 at least. I know the timing cover changed between them, but guessing it's still in roughly the same area. I believe oil temp is next to the pressure sensor at the front passenger side as well. Easier to get to if you remove the alternator (at least on the 8.3).
jpolen21
