Water/**** Nozzle location
litemup
For you guys that are running water/**** and are using Paxton SC where are is the nozzle location. Is it before the blower, or after the blower? I called Paxton and they said to install the nozzle before the blower, but I've asked a couple of guys including my builder and they said to install the nozzle after the blower just before the throtle bottle. I'm confused.
mine is a DLM setup but mine is already plumbed after the SC which is before the TB's.
L
litemup
DLM built mine as well. Do you have any pics of the location of the nozzle? If you don't mind could you post them for reference?
BOTTLEFED
Pocatello,ID
On turbos and centrifugal S/Cs you want the nozzles injecting after the air is compressed.
The **** will eat away, slightly, at the thin turbine blades. And you will get a better aftercooler effect if it is cooling the already compressed air.
dun4791
Peotone, Illinois
If you look closely you can see the 90 degree fittings after the throttle bodies going in from the sides on the intake manifold.
Missjazzyfitness
