What differential is in the Gen 5?
TrackAire
Vacaville, California
Does anybody know what differential is going to be used in the Gen 5? I figured it was using something special, possibly an active diff since Ralph said the rear scoops were for the differential cooler.
An active diff, if set up correctly could be controlled and programmed for different tracks, tire compounds, handling effects, etc.
Cheers,
George
I Bin Therbefor
It's a "Frame-mounted hypoid bevel gear with GKN Viscolok speed-sensing limited slip differential, 3.55" according to press release.;)
jpolen21
