A/C leaking on passanger floor.
2000GTS
Miami, FL
Noticed that the mat on the passanger side was wet this weekend. This morning I saw water coming down from under dash. I assume this is from the AC. My Ram had the same problem, There was a tube coming out of the firewall that was clogded. When I cleaned it out it solved the problem. I looked for the same tube on the GTS but couldn't fing it. Anyone know where it is?
Thanks,
Bill
2000GTS
Miami, FL
Where is the AC/heat fan. Can you access it from under the hood, or do you have to go under the car?
Thanks,
Bill
monoman2345
