Best tips for Storing a viper...
radta7
Roselle, IL
All,
Winter will be here in the North in no time and I am curious as to the best way to store a Viper. I was going to throw it up on the lift and cover it. I will also buy a battery tender bc I am NOT taking the back tire off to disconnect it. Should I add anything to the fuel tank other than topping it off??? Any help would be greatly appreciated.
Thanks in advance...
PS. Corsa and hiflo's go on next week!
tim721
west milford, nj
This was posted by Ron before - it should help
For those new to Viper hibernation:
As winter approaches, proper storage practices will insure that your Viper will be the same car you remembered it to be when you last drove it.
Engine and such…
If you’re due for an oil change, now is the time. Same for antifreeze. At minimum, verify it’s protection level. Brake and clutch fluid is another nice pre-winter maintenance item, especially if you’ve tracked the car recently or if it’s been more that two years since last flushed. Verify that your windshield washer fluid has suitable low temperature protection. Lastly and often overlooked is the battery tray. Corrosion runs rampant with a stock style battery and given that the tray is welded to your frame (GENII), keeping it clean and painted is cheap insurance. You’ll need to remove the left rear tire to gain access, but if you haven’t done it in a while, you’ll be surprised how bad it looks back there. Fuel should be topped off to minimize condensation and fuel stabilizer added then run /drive the car long enough to get the fuel stabilizer distributed throughout the system.
This isn’t to suggest that you should rebuild your car every fall, just that if these items are due, pre-storage is a great time to do it.
Body & interior
Wash, thoroughly dry and if possible Zaino the car prior to storage. Pay particular attention to the wheels as you do not want the corrosive brake dust eating your nice rims all winter. I highly recommend using a good quality car cover. Placing a clean cover over the clean body minimizes the risk of scratches. The interior should be vacuumed and all leather cleaned with a suitable cleaner / protector. Once cleaned, I leave both windows open a crack under the car cover to relieve pressure on the weatherstripping and to vent the interior, however if rodents are an issue, seal them up and place a few dehumidifying packages placed on plastic on the floor of the car. You can also place a small Styrofoam block under the wiper arms to keep the blades off the glass in order to extend their life.
Location & method
You’ll need to account for the characteristics of storage location, like the before mentioned rodent prevalence, moisture levels, access to electricity (for battery float charging) etc. Mice love stored cars and will find a way to get either inside of it or under the hood and then chew wiring, so a few well placed traps might be prudent if you’re storing in a location they’re known to inhabit.
Moisture is your enemy too, so putting a layer of plastic sheeting down and then parking the car over it will prevent the moisture that permeates the cement floor from condensing on your frame.
Your tires will flat spot if left in the same position over time. To minimize that occurrence, drive up over a tire sized pads of plywood, covered with a plastic door mat or remnant of old carpet. This in combination with inflating the tires to 44 PSI (or whatever the sidewall maximum is) will help the tires stay true.
Our Vipers will drain the battery rather quickly, sometimes within 2 weeks, even with the alarm off. If you have winter access to electricity, a Battery Tender brand charger or similar is mandatory. There are many “trickle” chargers out there, but over time a trickle charger will boil away your electrolyte, leaving you with a dead battery in the spring. The Battery Tender charger will not. I plug mine into a surge protector to isolate the car’s electrical system from the AC lines, just in case. I’ve also hard wired in the connector to the under hood positive jumper and frame ground in order to make the Battery Tender connection easy and fool proof.
If you do not have a tender or access to electricity you’re left with 2 options. Starting the car every 2 weeks or so (not recommended) or disconnecting the battery completely and periodically charging it manually.
Since the bulk of engine wear occurs at startup, I am of the belief that minimal over winter starting is best. If once every six weeks or so I get a particularly warm day, I start the car to recoat the cylinder walls and move fore and aft a bit to shift the tire position. Some really cold years though, I don’t start it at all. Do whatever feels right to you. If you do start it though, it’s important to let the engine fully warm up in order to evaporate any moisture that’s in the oil and exhaust system. No cold revving and watch the ambient temperatures if you’re using a thicker than stock oil (for example, higher viscosity than the factory fill 10W-30 Mobil 1).
I use my parking brake religiously therefore it’s always operable. If you use it infrequently, you might want to try it a few times to loosen it up prior to winter storage. Assuming the car is dry, using it over the winter should be no problem. If you prefer not to, be sure to securely block the wheels. I do not leave the car in gear over the winter because the rubber insulating boot underneath the leather shifter boot will take a set and make the first day or two of spring driving a bit odd as the set rubber resists as you shift into in any gear other than the one it was in all winter.
Winterization Checklist:
• Full fuel tank
• Gasoline stabilizer added
• 44 psi tire inflation pressure
• Plastic sheet completely under car
• Tires resting on plywood and carpet to minimize flat spots
• Fresh engine oil, possibly brake and clutch fluid too
• Engine antifreeze level verified
• Windshield washer antifreeze checked
• Clean interior and exterior, then cover
• Battery tray and battery terminals inspected and cleaned
• Battery Tender connected
• If needed, mouse traps and dehumidifier bags placed, otherwise windows opened slightly
Spring Checklist:
Don’t forget to adjust tires down to 29 PSI before driving and observe the inflation pressure prior to adjustment. Are they all tires equal or is one low? Could be a slow leak that’ll require watching.
Dohhunter
Toronto, Canada
The following is what I follow for my cars:
1) Change the oil prior to storage, drive to full temperature and then turn her off. Leave it until spring startup, unless you are going to drive your car when you start it in the winter, moisture and condensation are your enemies (result from not letting the car warm up to operating temperature, which doens't include just idling!).
2) Pretty much standard to wash, fully dry, wax, leather dress and treat the weatherstripping.
3) I put squares of carpet under each tire (inflated slightly higher than recommended) but you shouldn't have to worry about flatspots, that was a problem in old ply tires. You might get temporary ones after winter storage, but they'll work themselves out after the first drive.
4) I also put full sheets of carboard or old carpet under the entire car, especially important if parking on concrete. Again, moisture/dampness and condensation are your enemies.
5) Pick up some Sta-Bil gas stabilizer to treat your gas. AND FILL UP YOUR TANK RIGHT TO THE TOP.
6) I usually use 2 moisture absorber bags in the interior, and 1 in the engine bay.
7) Keep your windows slightly cracked.
8) Use a car cover.
That's it :)
95Viper
Phoenix
I plan on using one of those bags to seal my Viper in.
How can I use the tender? Poke a hole through and figure out how to seal properly? Can I clamp it to the post under the hood?
Dohhunter
Toronto, Canada
Hmmmm I gather you are referring to a "car capsule" like bag? the ones that use a fan to circulate air and keep it inflated?
If that is the case, I'd either:
1) Remove your battery completely, this is what I do with both my Vette and my TransAm. Your radio will need to be reprogrammed come reinstall as well as your PCM having to get relearned (a good first spirited drive will fix this :) )
2) Cut a hole in the floor of the capsule. I'd run the power cord under the floor and up, should be easier to seal I'd think and you wouldn't be compromising the plastic.
Dunno, I'd just choose option 1 :)
95Viper
Phoenix
Not that one with the fan that keeps it inflated. Just the one like a big zip lock bag.
Do you think I could poke a hole in there and figure out a way to seal the hole with the cord through it?
watersnake
Corpus Christi, TX
My suggestion for winter storage is to move down to my neck of the woods where you can drive it year-round-- and usually *******. You might occasionally get a tad chilly with the top off.
Dohhunter
Toronto, Canada
Sure, don't see any reason why not. Even better, zip it up until about 1/2" closed, then exit the cord through there.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
C'mon guys - you're ruining my day! :( Way too early to think about putting the Viper into hibernation.
<font color="red">Time to drive it like you stole it! </font>
IEATVETS
Cottage Grove, Wis.
Wash it, wax it, check tire pressure, fill er with gas along with some stabil, park it over a piece of carpet, raise it off the ground, and forget about it. Unless you can fully warm up the engine which does take a while, don't start it. You do more harm than good when you do that. Also, hook up a battery tender.
ViperJoe
Virginia
Keep driving it until you HAVE to store it (snow in the forcast, or sand and salt already down).
STUGOTS
NY/CT
OK IM GOING TO SHARE MY SECRET WITH YOU ALL.
The best tips to store a viper.............
1. live in flordia or any other place where its summer all year and enjoy your car 365 days a year.
I need to take my own advice.
viperama
Bern, Switzerland
I allways put two of those stainless steel cylinders filled with silica gel in my car.
They absorb humidity and each can hold nearly a quart of water!
You can reuse them nearly unlimited.
Simply put them in a oven (ca. 180°F) or lay it on a radiator over night.
For more information click HERE
HavikPerformance
