Gen-1/Gen-2 CP Pistons, ONE SET ONLY
Cape Coral, FL
I have ONE set of Spare CP Pistons available immediately. 1500HP Design, 4.030 Bore, .927 pins, ALL options, will mate directly to Eagle Rods for a Drop-In Forced Induction build. 9.0:1 compression w/stock heads on a tight quench w/.040 gaskets. Pistons have a full coating package, and are brand NEW. Price is 500 bucks off!
I also have a spare Gen-2 engine block/crank/heads laying around. I can BUILD TO ORDER a VS-1000 block in a matter of a couple weeks on request, for a smoking price.
Any takers?
mbccenter
Legacy Supporting Vendor
Forest Lake, MN
Dan
I have a set of Oliver rods that I can check the specs on. Are these stock stroke?
Matt
Cape Coral, FL
Dan
Matt
Yes, designed for stock stroke. They were spec'd originally for a 3.88 stroke on a 6.123" rod, and will achieve zero deck w/9:1 and a .040 quench on .040 gasket with stock heads. They have a reverse chamber dome profile, anti detonation grooves, accumulator grove, gas nitride top ring w/lateral gas ports, napier second, 3mm oil ring, and .200 wall 9310 pins.
Cape Coral, FL
Picture:
[If purchased w/rods. Note: Rod shown is Carrillo, though Eagle looks almost identical]
attachment.php
attachment.php
