Crank, no spark, no fuel
Timothy McManus
PA
I have an early 1993 RT/10, was running great until I went out to the car one day and it just cranks, but never fires over. I checked all of the fuses in the passenger footwell, they were all good. No smell of gas out of the exhaust after cranking. I put a spark tester inline with a few of the spark plugs and I’m not getting any spark while cranking. I can hear the fuel pump running for 2 seconds when I turn the key to run so I am assuming there is good fuel pressure. I have a fuel pressure gauge, but don’t see a shrader valve anywhere to measure it. When I check the engine codes I get:
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
33 A/C clutch relay circuit
55 End of error messages
Code 33 has always been there, but idk if it could have anything to do with this new issue.
My thoughts are a crankshaft position sensor, camshaft position sensor or ignition module or something else that I’m unaware of. Does anyone know a way to narrow down the problem?
Cape Coral, FL
Crank engine. Listen for fuel pump run-on for a second after engine stops rotating. If you are getting FP activation, unlikely to be crank sensor issue, more likely Cam sensor. Otherwise, no FP activation when cranking often = bad crank position sensor.
T
Timothy McManus
PA
I put my hand on the fuel pump relay and could feel it kick on and prime for 2 seconds when the key was turned to Run. Cranked the engine over for about 5 seconds and felt the fuel pump relay turn on for maybe ½ a second. Cranked the engine a second time and did not feel the fuel pump relay turn on at all. I have a new crankshaft position sensor on the way and will update once I get it switched out.
Thanks Viper Specialty for the helpful insight
T
Timothy McManus
PA
The tachometer didn’t move at all while cranking, but I did get some oil pressure after a few seconds.
T
Timothy McManus
PA
Just replaced the crankshaft position sensor, still no spark, no fuel, and no rpm showing on the tach. Any other ideas that I can try?
T
Timothy McManus
PA
I checked all the fuses, and checked power and ground to the ignition module and ECU. Everything looked good there Are there any hidden fusible links that might be blown?
Cape Coral, FL
If you are 100% sure you are getting power/ground at PCM and IGN, have a good crank position sensor, good crank position sensor wiring, fuel pump activation at key-on... the last hail-mary is a Cam Position sensor [unless you are capable of probing the sensor output with a DVOM and manually rotating the engine waiting for the sensor output to change in order to verify functionality].
Beyond that, your PCM becomes suspect in a hurry, it may be dropping out right after activation due to internal shorting. We are the supplier for those, but you need to check sensor inputs first.
Unfortunately your hands are largely tied without access to a DRB-3.
WARNING: If your PCM is dropping out shortly after key-on, you are absolutely riding the edge of a full-on PCM meltdown. I strongly suggest leaving the PCM disconnected when you are not actively working on the car until the problem can be verified. PCM meltdown can occur even without the key in position, as they are powered all the time. Cost difference to replace a PCM without a core vs with is huge. Dont risk damage pointlessly while figuring this out.
Have you tried swapping the ASD relay with the starter relay...since you know that the starter relay works ?
Good point, Dan.
The Schrader valve port for reading fuel pressure on an early Gen I is at the very rear of the driver side intake manifold... noting that it faces the driver. You might need to remove the windshield cowling to get to the port. It might be helpful to put the gauge on it before and during cranking engine to be sure that you understand just what the fuel pump is doing.
T
Timothy McManus
PA
I disconnected the battery and am going to bring home an oscilloscope from work to look at the output of the crankshaft position sensor and the camshaft position sensor while cranking the engine over. If both of these signals look good, sounds like the next step is to send in my PCM and have you guys take a look.
Good point, Dan.
I will check the fuel pressure tomorrow as well, thanks for telling me the location. I am assuming that it’s not just fuel related though as I still have a spark tester inline with the spark plug and still have no sparks or fuel.
Where in PA are you? There is a really good shop in Bath, PA just North of Allentown
T
Timothy McManus
PA
I live in State College, do you know if that shop has a DRB3? Sounds like that’s what I need to further diagnose the problem. I could get a trailer to tow it over there.
T
Timothy McManus
PA
Ok so I got the scope and it looks like I have good signals on the crank and cam. I took screenshots, yellow is the cam and blue is the crank.
I also took a look at the power to the injectors while cranking. I see voltage and hear the fuel pump when I first turn the key for about 1 second. Then when I crank the engine I will only get power to the injectors for a split second on maybe 1 out of every 5 tries or so. Besides the cam and crank sensors what else is required for the ASD relay to energize? Just want to eliminate all options before I send this thing off to the professionals
As I recall the wording, if the PCM does not receive the appropriate signals from its sensors ( crankshaft, camshaft, upstream O2, MAP) within one second of the engine cranking, the ASD relay will shut off spark and fuel...hence the question that I asked in post #10 of this thread which was: "Have you tried swapping the ASD relay with the starter relay...since you know that the starter relay works ?"
Cape Coral, FL
As steve said, now you need to figure out if your ASD wiring and relay are intact and operating properly.
Crank and Cam are really the only sensors that are critical to ASD/FP activation. Even with a bad or disconnected MAP, it will usually start and barely run/pop/bang if I recall as it defaults.
T
Timothy McManus
PA
Sorry for the late reply, haven’t had a chance to get back out to the viper until now.
I tried swapping the starter relay with the ASD relay with no luck, car still cranks but does not fire. I checked the wiring of the ASD:
Slot A had 12V with key on and during cranking
Slot B had 12V and continuity to cavity 57 of the PCM
Slot C had 0 Ohm continuity to pin 51 of the PCM
Slot D had 0 Ohm continuity to the 12V feed pin on a injector
That all seems to check out. Also when I cycle the key on and hear the fuel pump prime I can feel the ASD relay click. It doesn’t click on when cranking the engine. At this point I am really starting to dread that it is inside the PCM or Ignition/Injector Driver Module (IIDM)
I know that I had a good cam and crank sensor signal at the IIDM connector, so I also checked continuity between the IIDM and the PCM:
PCM pin 24 to IIDM pin 20 = good crank signal
PCM pin 44 to IIDM pin 21 = good camshaft signal
Also checked the SCI communications between the two modules:
PCM pin 25 to IIDM pin 31 = good SCI transmit
PCM pin 45 to IIDM pin 22 = good SCI receive
Is there anything else that I could be missing or is it time I package them up and send them off to Viper Specialty?
T
Timothy McManus
PA
Forgot to add that I ran a jumper from slot B to Slot D of the ASD relay connector and it still didn’t start
T
Timothy McManus
PA
…and one last thing, I have to press the unlock button on my remote to stop the lights from flashing when I reconnect the battery, but the last time 2 times I was cranking the engine, the horn started to beep like the alarm was going off.
When I press the lock button I get “alarm set” blinking on the dash and the horn chirps. When I press unlock I hear a click click sound. Not sure if the alarm could be the culprit at this point, but I seem to remember that it would let the car fire up and then die when it was armed.
T
Timothy McManus
PA
Had a great chat with Steve this morning, tried out his trick to disable the alarm system, but still a no start condition. Also verified fuel pressure is just under 60psi when primed on initial key on. It bleeds down slowly, but does not come back up again when cranking (no activation of ASD or Fuel Pump relays when cranking).
I can pull the PCM and IIDM or whatever you suggest and send them your way
Cape Coral, FL
I would suggest double checking the continuity of the wiring through the connector itself and make sure no wires are broken at the PCM or ICM, but beyond that... yes, sounds like there may be an internal issue here.
T
Timothy McManus
PA
Just went out and double checked everything on the PCM and IIDM connectors that I could think of and still nothing.
I’ll shoot you an e-mail to see what I need to do to get it mailed down to you.
Thanks everyone for all the suggestions and help.
You have signal but are they in sync (o would have to dug around).
And your Slot A, B I can not follow as they are 85, 86, 87, 87a and 30 pins on vehicle relays.
Pin 87 is the feed to the coil packs, O2 sensors, etc. If you jump a constant 12V (pin 30 is supposed to be hot all the time) to 87 of the ASD and fuel pump relays, the circuits will all be hot.
Edit: just saw this is gen 1 not 2. I only have SM for gen 2. I will look at the posted diagrams.
T
Timothy McManus
PA
Yea there is always 12V on slot B (30). I don’t think that it is a relay wiring related issue as I have jumped slot B (30) to D (87) and still no firing.
Also the ASD relay and fuel pump relay reliably turn on when the key is turned to run. Both relays engage for about 1 second. I then get a very random engagement of both relays during cranking, only for a split second every 5 or so attempts.
I posted the Crank and Cam position signal outputs, so I have good signals. They could be out of sync but I would think that would throw a code.
Currently just waiting on insurance to see if it is covered or not, then will send the PCM and IIDM over to get a replacement.
Open to any and all ideas in the meantime.
Miggy
