Gen2 turn signals and hazards not working, need help!
manolodf
Hey guys, I'm in need of help on my gen2 2001 rt/10, basically I have no turn signals or hazards, I'm hoping it's just a fuse but I cannot figure out which one it could be, the diagram on back of the dash lid is not very clear to me how they match up to the fuse box, can someone please tell me the number of the fuse I need to pull and check please (they are numbered in the fuse box) so I can hopefully quickly fix it or see if it could be something more serious.
Thanks!
V
Venomiss
Guest
Found the following information using the search feature.
Plug in turn signals and many threads appear.
Turn signal flasher power goes through the ignition switch, then fuse #19. Headlights are powered by fuse #14, then through the headlight switch, then through fuse #3 and #4. There is also a circuit breaker in the headlight switch. One common item is the turn signal stalk/dimmer switch. Maybe the connector under the dash is loose?
Or, you need a service manual with the wiring diagram.
M
manolodf
I got it resolved, Thanks for the help on the fuse numbers, I also received some help from Chuck Tator and he mentioned Fuse 19 and Fuse 6 are the ones that control that system, and I took a look at my dash fuse box and fuse 19 was just not there! So i slapped a 15A fuse in there and everything was working great after that!
