Hard top
94yellow
pa.
Need some help finding what make of hard top I have on my
1994 viper. I can not see any ID. any where. The sports bar
is removed to put the top on, which might eliminate some.
Any help with identifing marks on others let me know. Thanks.
Jeff Torrey
Plaistow, NH USA
I think you have to remove the Sport Bar for the Autoform and Mopar Hard Top.
The Autoform top has arched sides to work with their arched windows.
The Mopar Top is basically level or slightly curved to work with stock windows.
So if the Top works with stock side Curtains then my guess is you have an Gen 1 Mopar Hard Top.
lobo
Palm Harbor, Florida
I just bought my '94 two weeks ago and it has the original Mopar hard top which requires the sports bar pad to be removed. I found an installation sheet in the glove box and it says Mopar on it so I'm pretty sure it's a Mopar hart top. The sheets too long for my scanner or I'd post it for you. The top surface is not flat and has two slight bubbles. It uses two long bolts in the rear that are allen head and the front two latches have very short arms. I looked all over it for a part number, but found none. I hope the photo helps ID yours.
I shot a pic of the drivers side front latch and one of the underside...maybe that will help.
94yellow
pa.
Thanks it sure looks like the mopar top as the soft top has never be on the car. The latches look the same and the side windows work with the orginal and vipermania windows. Thanks for the help.
countourcafe
