HID Xenon Viper headlights now in stock and shipping out..
Sean Roe
Jacksonville, FL
To those who had ordered, thanks for your patience. The parts came into Jacksonville Monday and cleared customs Thursday. I've been building up the Viper kits and will be finishing more today. They came out quite nice. Everything fits within the headlamp housing and requires only one connection and no tools
Here's an installed picture
BurnR8
Redmond, WA
SEAN!!! you are the man!! I cannot wait for these to go in...I will be the first kid on the block for sure!!!
jwwiii
Waukee, Iowa USA
Dear Sean;
What are the trade off's involved if one switches to the Xenon lights? I was wondering why the Viper did not come stock with them if most new luxury cars seem to offer them for an option. Is it just a price issue?
If I change to the Xenon, what are the benefits? I have seen the "blue lights" on new cars, and can only speculate that they must be brighter, or easier on oncoming car vision. Are the Xenon more demanding on the Vipers electrical system? Does my new 01' RT-10 already have them? (it's in storage with 15 miles on it, covered up... we have lots of cold, salt, and sand). I expect my Viper does not have them.
Please post more info on the benefits of the Xenon. The lights seem to be the current bulb of choice.
Sincerely,
Jim
Sean Roe
Jacksonville, FL
Hi Guys,
Sorry I didn't get back faster with answers to your questions, but it looks like Larry M. and Ron have been helpful with answers.
The conversion kits we worked out have the Xenon gas capsule centered within the projector lamp housing at the same location as the stock halogen bulb filament. The Xenon bulb is fully exposed (unmasked) and is the type needed for projector lamps.
The original wiring size and fuses do not have to be changed on the Viper for the use of HID Xenon systems. Hid systems have a short time of higher amperage draw at startup, but quickly drop down to under 7 amps. The original Viper 20 amp headlamp fuse is what Philips recommends for the kit.
HID conversion kit prices have come down a little. They used to retail at about $1,100 for a pair, but have come down to about $850. We get our parts from an overseas supplier and are offering them prepared for the Viper at $569.00 a car set.
They go in the low beam socket so that you have the benefit of whiter and broader light at all times, (the lows stay on when you turn on the highs). The headlights do not have to adjusted specifically for HID lamp use. If your headlamps (with stock bulbs or otherwise) are out of adjustment, you have the ability to use the headlamp bubble levels in the housings and the adjustment screws inside the housing to adjust them yourself without going to a dealer. On American made cars that did not come with HID systems, HID conversions are not DOT approved. As long as your headlamps are not out of adjustment and blinding other drivers, you should not have a problem (as with any lights).
Here's a couple pictures comparing a Viper with stock halogen bulbs to a Viper with HID Xenon bulbs. The halogen equipped one is the yellow looking one in the photos. And no, I didn't doctor the photo, there's just that much of a difference
jwwiii
Waukee, Iowa USA
To Larry/ Imorreti;
Thanks for the thorough Xenon bulb response. WOW! You definitely have all the info anybody could ask for.
These bulbs that Sean is selling sound like quite a substantial improvement over stock. If I understand correctly, the Xenon require a little more power at start-up, and then require less juice than the stock Halogen but give more usable light. Do I have this right? My biggest question is, "what are the downsides" to buying these lamps? More heat that could melt something like the plastic lens? Electrical system barely adequate? That sort of thing.
Sounds like a great product for all of us. Is there any risk to changing to Xenon that I don't understand?
Thanks alot for all of the info!
Jim
Sean Roe
Jacksonville, FL
jwwiii,
HID Xenon operates cooler and will not melt your Viper headlamps. The stock wiring is adequately sized. The only downside is the price, and I've done my best to reduce that.
These are an $850 option available on some Mercedes Benz models.
Vip08
