I was doing the DANCE!! My personal best so far...
utahviper
Utah
Let me explain why I am so happy! Up here in the land of thin air I achieved one of my goal's of reaching the 10's. Maybe you guys don't see anything for me to get happy about but up here that is huge!
My H M S 650R achieved a best 12.0@118 MPH (536RWHP/555RWTQ Corrected)with about 30-40 runs down the drag strip. Last year we went to hot august nights in reno and I decided that one evening we would go to Sacramento Raceway to see what my car could do @sea level. I have never been to that track nor have I driven my car with that much actual HP. Needless to say that one evening is not alot of time to get used to my extra 80-90HP. I made somewhere between 5-6 runs on kumhos with two 11.2's @126MPH. I couldn't believe that I got .8 of a second my first time out when it was ~95 degrees outside.
The only reason I bring this up is to tell everyone that anything in the 10's at our track http://www.rmrracing.com/2003/drag/drag-strip.htm is quit an accomplishment. Our density correction factor last night was about 8000-9000ft, it ranges between 7000-1100 ft. The temp was around 93-94 degrees.
I achieved this time on BFG drag radials. All my buddies and I were doing the dance because I passed a great barrier here in Utah that only bikes really pass. Hayabusa's run around 126-128MPH in the quarter and all the others are less MPH. NOtice my MPH is down from my best because it was so hot!
I will say that if I went to sea level I would see at least a .5 off to as much as 1 second off my time. I know that forced induction makes a difference at altitude but not until you are running high boost! I have talked to several drag racers that go to sea level and they have said NA and low boost cars pickup between .5-1 second and that high boost cars (27lbs or more) don't pick up but maybe .1-.2.
Maybe we can get our viper brothers in Denver to chime in and post some of their times with HP numbers. I know they suffer from the same problem as me, thin air! I also think that there are some New Mexico members here that also have a high altitude drag strip.
Sorry for the long post but I am going to post a in car poor video so everyone can see how slow I shift.
I am soooooooooo excited to be in the 10's at high altitude.
Larry Macedo
Sanford, FL
Congrats again, Todd! You were so close that I knew when you called last night it was great news regarding an awesome accomplishment. Ready for the SSCC in September?
Moundir
Ny
holly crap that's freaking low 10s at 140mph territory that you have accomplished :eek: You trap higher than busas too :eek: I knew once I saw that tq plateau (which I have saved as my favorite dyno sheet in the whole wide world)that you had a killer setup. Congrats man, you def deserve it :)
U
utahviper
Utah
Well I am going to post a link to my in car video. The video mount was rigged in about 10 minutes so after my burnout the tires stick and the camera goes sideways but you can still see everything.
Sorry for the angled video shot but you can still see me shifting sloooooow. I have got to work on that.
http://www.computersales.com/images/10.94(1).avi
Let me know if it works
Moundir
Ny
awesome vid, it work just fine :) let me guess you have the viper inovations camera mount ;) Mine does the same thing. Btw your track let you run 10s with no helmet at least :eek: What rpm did you leave the line from??? Sounded like around 2k or so :cool:
U
utahviper
Utah
riverflyer
I only have between 575-610RWHP actual at this elevation so in order for me to hook I have to use either BFg's or Kumhos drag tires. I heat them up and slip the clutch @2200-2500rpm. I haven't been able to get the tires hot enough, I do not have a line lock, to rev it to 3500rpm and hook on the starting line.
Moundir
I am glad the video works! This was a homemade mount I threw together in about 10 minutes. I would like to get a good in car video mount if you know of one. I did have a helmet on but it is a motorcycle helmet. You can see my visor in the video. My track is very strict! I have everything you need to be in the 11's but I am not sure about the 10's.
