Need A DRIVERS Side Sill Insulation Pad
ViperJoe
Virginia
I need a drivers side sill insulation pad.
NOT toasted please.
No luck with Larry, Paul, or X2
ZOOMBI U
Newmarket, Ontario
If you are having a problem finding insulation in good shape try using 1/2" ceramic insulation blanket used in air tight wood stoves.
V
ViperJoe
Virginia
Tony,
He does show the out and inside of the sill insulation. It's on the other pics
That's what I am looking for. The insulation blanket.
Seems that near about all that I have looked at however are all toasted whereby the soft insulation (what's sandwiched inside of the aluminum)gets rock hard, negating any of the parts insulation qualities.
I have even looked at a few that are burned through!
Mileage plays a big part in how these things look and hold up as do hi-flo cats.
Tony, check your pm
Thanks for all the help guys......looks like when it rains it pours.
Been looking since April with no luck, now I have 3 or 4 prospects!
Go figure......the world of salvaged / wrecked Vipers!
Jeff48
