New headers/exhaust - check engine light on. Annoyance or functional loss? Fix? nt
SoCal Rebell
Mission Hills, Ca USA
I beleve it's an annoyance, mine comes on also, but no loss of power.
Fix, I put on a Mopar HiPo ECU, got rid of light but I LOST 25 hp & 20 ft-lbs. of torque, I have the stock ECU on now and will live with the light.
LTHL VPR
I had the problem in my 98 GTS when I removed the cats. Every now and then the light would come on. When it was on, it did not effect my A/F ratio or power according to the dyno.
Sean Roe
Jacksonville, FL
What trouble codes are you getting on the '98 and newer cars? Is it a catalyst efficiency failure code or something else (catalyst heater)?
Are you getting the codes when still running stock cats?
Let me know and I'll see if I can help find a solution.
Jaymz
Cincinnati, OH
I am getting codes of 1281 and 1494. I will not get the codes if I allow the car to warm up before driving. My theory is the O2 sensors are heated and will not function properly with a cat until fully heated. It generally only takes a minute or so.
A
ACR Joe
Newtown, PA
Sean:
As the car has been prepared for off-road use, the cats have been removed. I have not checked the fault codes, but will do so and report back to you asap. The car is equipped with Belanger headers and exhaust system, but no other modifications.
I disconnected the battery to clear the code(s); upon restart, the light illuminated immediately.
Thanks .....
No members online now.
ctrengine
