- Joined
- May 1, 2004
- Posts
- 3,471
- Reaction score
- 2
Paxton with boost gage, what\'s your max boost?
Title says it all. If you don't have a boost gage, you can pick one up most anywhere. You can check by tapping into the vacuum line with a "T" fitting and about 3 feet of vacuum hose. The easiest place is where the vacuum line from the engine feeds into the split second unit under the dash, drivers side, right. Your passenger can them watch the gauge while you drive.
Paxton states that max boost is supposed to be 7.5 psi. Mine made 9 psi at 6000 rpm. Probably why I've had problems as discussed in another post.
This would be interesting to know.
