Springs and caps on 345/35/18 drag radials?
Junkie
Is anyone running that low on drag radials? I've got 345/35/18 M&H's with springs/caps and it rubs on bumps and heavy suspension load. The M&H supposedly runs .5" or so taller then the MT in the same size so I'm wondering if I can run the MT's without raising the car up.
Raven2k8
San Diego
With a stiffer setup from coil overs you would probably be fine. I have the same tires with caps and I have rubbed only one time with two people in the car and some nasty dips in the freeway. The stock suspension is just terrible. I will be getting some coilovers soon.
Tiago
Houston, TX
yes it will rub a lot on that setup... almost undrivable.
Get coil overs and adjust the ride height appropriately.
xeng yang
