a/c blower problems...any suggestions?
RED97GTS
Lurking Most of The Time
Do you still hear the blower under light accel. You might just be experiencing a drop in vacuum that diverts the air. The system could use a vacuum reservoir.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ChipH:
Under moderate acceleration, my 97 GTS's a/c or vent blower motor quits blowing all together. If I lift, the motor begins blowing again.....Now, my check engine light came on, and the car is sluggish. <HR></BLOCKQUOTE>
The former is NORMAL and the latter is probably not related at all. My bet on the latter------an old, tired battery, or misfiring wires/plugs.
Routine maintenance should include PITCHING the old battery before it weakens,dies (3 yrs?) .......and replacing plugs ($20) every 7K mi and wires ($79oe-$998.5mmHT) every 12-15K miles
ACR Joe
Newtown, PA
It's the diverter door redirecting the air flow as a result of low vacuum during moderate throttle, low rpm operation. NORMAL!
Install a vacuum reservoir to (largely) negate.
luc
Paso Robles CA
ACR Joe is correct.
I had the same problem on my 2000 GTS and installed a vaccum reservoir.
I got a brand new one from Jeep (about$7)that is about 4" by 5".
I find a neat place for it just under the windshield washer bottle, using the ground stud to secure it.
You just have to run the vaccum line from the intake to it and then connect the original vaccum line from the heater/AC to it.
Now I can be at WOT for a LONG,LONG time and the blower blow.
If you want the Part# for the vaccum canister, let me know.
And thanks ACR Joe for the tip.
Luc.
Kansas City,MO
Luc or ACR Joe do you have a pic of the vacuum reservoir mod. I have only experienced this problem in 6th gear. It is annoying. I remember this being brought up at VOI-6 in the "Tech-Session". No action resulted from what I have seen.
ACELLR8
Harrisburg, PA
I thought that was the way they were designed, to cut off the AC/blower under acceleration. To give the power back to the car. That is what I have always believed about this. My RT-10 does the same thing.
Cerevo
