Best replacement Radiator
Caesar!
Toronto, Ontario
I have a 97 GTS and my rad is leaking and probably due to replace it.
What's the Best replacement rad...direct bolt in to use?
And it would probably be a good idea to replace to upper/lower rad hoses too.
Who do I call?
TP_ GTS
I had mine re-cored. A fellow member recommended a local shop here in Florida. They re-cored mine adding a 3rd row. It was a plug and play when I got it back! No fitment issues with radiator or hoses that you sometimes hear about with the aftermarkets. Costs to re-core is not too far from a new aftermarket one but the fitment, not having to modify, keeping OEM and knowing what you are getting was worth the piece of mind for me. Talk to a reputable local shop and go from there. If you can find a used OEM, you can send that off and have a spare when you take yours out.
Gen3CoupeTX
Sienna Plantation, TX
A recore never hurts. Running hot, or causing worry while you drive is not much fun. I tend to overdo this area, as I like to not wonder if I have enough. I'm a Ron Davis fan, but have also used competitors depending on the car / availability.My supercharged stroker '06 Coupe stays cool in Houston, TX ... Not the automotive world's easiest cooling venue.
Skolnick89
Springfield NJ
Mine is a 1998 GTS.
Lower corner of radiator shows green leak but nothing on garage floor. My mechanic recommends a new radiator and wants to install a thicker radiator and as 99+ fan is super expensive he wants to fabricate a fan assemble.
Question is, do I buy aftermarket drop in radiator or larger aftermarket?
Opinions please. I do intend to do some track days
SKY1960
