bumper adjust
22YRSOLD
how do u adjust the spacing between your hood and your bumper on the outside where the lights are. basically above the side markers. is there a bracket inside the bumper assembly where it could be adjsted up and down.
BDZ1984
Frisco, Texas
its not that easy... lots of adjustment with the bumper and the core support.. take it to someone that has adjusted them before.... It will save you time and the headache
Quantico, VA
You are usually better off trying to adjust the HOOD via the latches and bumpers. :) Ajusting the area you refer to means loosening many other panels to ajust the "knife edge" that fills that slot. Personally...I'd rather do ANYTHING else in the world than mess with that any more than I have! :) Good Luck!
22YRSOLD
well i think the hood is fine. i run my finger through the top of the ;ight prety even spacing. the problem is the bumper. but i hear ya. maybe ill just eave it alone
