prosthogod
I just got my car back after having this put on. It sounds great, the reduction in heat is great, but it seems to be a little slower to respond off the bottom. Is this common?
So what happens to the exhaust metal temperatures when you wrap the exhaust up? Seems like the growth issue that affects tip centering would be worse with higher metal temperatures.
Not sure if you are also wrapping the catalysts but the resulting catalyst internal temperature would be of significant concern.
My Mopar race exhaust runs cool enough that sill temperatures are not an issue. I would certainly never wrap or insulate the exhaust. I would prefer if anything to improve the air flow over the exhaust to keep the exhaust temperature as low as possible. Gen I and II had a kit to install a screen in the wheel well in front of the sills to aid cooling. That may be of benefit for the Gen III as well.
