You can also CHANGE some of the options..........(which aren't in the service manual)
Horn Chirp Disable:
1. Press LOCK button 4 seconds.
2. Within 6 seconds with the LOCK button still depressed, depress UNLUCK button.
3. Repeat to enable.
Optical Flash Disable:
1. Press LOCK botton for 4 seconds.
2. Within 10 seconds with LOCK button still depressed press TRUNK button.
Door Unlock Sequence (unlock all doors at once):
1. Press and hold the UNLOCK button for 4 seconds.
2. Within 10 seconds with the UNLOCK button still depressed, depress the LOCK button.
3. Repeat to return to driver door first.
