I have That Itch Again
Dimitrios
Queens, New York
ok guys i have the itch again..i have headers,cats,cat back exhaust, roller rockers. what can i do next besides the SC or turbo to get some more horses??
D
Dimitrios
Queens, New York
someone else said that. where do i get heads and cam from. what are their prices. i dont see em on partsrack or roe websites.
STUGOTS
NY/CT
Well if you ever plan on doing a S/C you should wait on the heads/cam because you have to have nigher compression for N/A and lower for S/C so you would be losing a little bit of power until you got the S/C.
So I would go with an aluminum flywheel I hear they add some bigtime pickup and maybe some 70mm TB's.
BTW S&B filters are ALOT better then K&N they gave me 7 Hp more then the K&N's.
RC Viper
Cary NC USA
When you say heads and cam which ones do you mean? I am about to put a set of stage 3 heads on the car, but did not plan on making a cam change. I have a 97 GTS with T&D roller rockers already installed.
Am I making a mistake not replacing the cam when I do the heads? I have been told that I should see 60 RWHP from the heads.
XS TORQ
San Jose, CA., USA
I would only do flywheel if you needed to change the clutch anyway. I never considered it a very good upgrade (did it anyway).
Heads and cam are going to make good power.
Maybe a rear gear change - unless you're going to get an S/C or TT, then you probably want to stay w/ stock gear.
My $.02
Casey
Valparaiso, IN.
Stop messing with it and buy an additional toy.
BOOOOOOOO!!! :p It's not fun having another toy if it just sits there because you always want to drive the Viper!! :2tu:
Heffner has a heck of a heads/Cam package that's well priced!
Marc Lublin
Oyster Bay, NY, USA
Don't bother with the heads and cam, you are only going to change the setup later when you put in a SC. Just man up and put in a SC from one of the compitent tuners!
Moundir
Ny
How about: Buy a new car!
look who's talking ;)
D you gotta decide how much $$$ you want to spend and base your decision on that!!! For the $$$ your best bet would be heads/cam and some 3.55s. (remember you have a cream puff so for you to make great power with the roe you will need to go into the engine) :smirk:
LIVIPER
New York
I was in the same boat. After doing the smaller less expensive mods, at some point the additional $$s to HP doesn't make sense. More and more $$ for small(er) gains. At this point the s/c actually makes the most sense. When I first bought this car, if you said I would be spending 8K on a s/c, I would have said you were nuts. Anyway, I have an appointment to drop of the Viper at Tator's this Saturday for a Roe S/C. My advice, GO FOR IT!!!
Kiaser
You could try lightweight underdrive pulleys. With that said you may also want to think about upgrading your radiator/cooling system.
Qdog
