MBX Gen II Steering Column Gauge Pods
D
DAMN YANKEE
Guest
Couldn't be more straight forward. If it is the same unit I bought from them, The most important thing is to be sure that you first set the steering wheel in its LOWEST position to give yourself the most room to "snap" the pod in place. One can also press the emergency flasher button to give it a lower profile. IF you find yourself forcing anything STOP you are doingsomething wrong.
There is plenty of room to sneak wires into the back. Just know that the pod has the tendency to lift on the right hand side over time as it is a friction fit. While a minor issue (I press it down ever couple of weeks), I have yet to find the right solution to tack it down. If anybody hs one, please let me know.
I run a D-PIC meter in the pod from Auto Meter.
D
DAMN YANKEE
Guest
Not sure, I'm afraid you will have to just fit it out and see....
techanvi
