cposk
The issue I am having seems very similar to the problem dom was having a while back(link below) which ended up being his cam sensor.
(http://forums.viperclub.org/threads...-she-missing-spark-fuel)?highlight=cam+sensor).
98 GTS. I bought the car in October 2011. It supposedly has Hennessy 600 heads and cam. From what I can see, everything else is stock. 38.5k miles when I bought it.
At about 40k, I started to get what felt like the motor "coughing". This would happen in low rpms when throttle was applied. I mostly started noticing it when cruising in 6th gear. After about 500 miles, it was happening more often, but still was very intermittent. I figured that it was old plugs not firing. Went to autozone, they didn't have the Champion brand plugs the FSM called for so I got the autozone brand. After putting them in, it was worse. So I eventually picked up a pair of the plugs that the FSM calls for and put them in. For couple hundred miles, it still happens every once in a while.
This only happens below 2500-3000 rpms. Sometimes at idle, sometimes not. It feels like a "hiccup" and can be heard through the exhaust. As soon as a get over 3k, no issue. Smooth and scary fast. Oh and no CEL, all gauges read normal.
I am going to replace the plug wires next, then the cam sensor. My questions are: Should I be using a different plug? Is there anything else I should be looking at?
