Oxygen Sensor/Exhaust Install HELP!
Chipster
Fredericksburg, VA
I have the stock exhaust (from cats back) undone and off the car EXCEPT the passenger side because the Oxygen Sensor bolt is striped and the open ended wrench is not catching anyway I try. I've sprayed on bolt/joint lubricant/loosener and that has not helped. How the hell am I going to get this thing off? Should I cut the wires? I really need some advice here. I was on such a roll getting this thing off till this happen. And unfortunately it was already stripped. HELP ME!!
C
Chipster
Fredericksburg, VA
There was only one section where there were O2 sensors and that was on the intermediate pipe after the side muffler and before the rear muffler. I ended up just cutting the wires. I'll have to get a new sensor and plug. Now my problem is getting the clamps on the 3" part of the exhaust.
Copperhead245
Jefferson, NJ
"Rear muffler"?, well then its not a GenIII - but you might not want to assume everyone knows what year you've got. Not trying to be rude, but I might have been able to help if it was a GenIII...
Ron
C
Chipster
Fredericksburg, VA
Haha, my fault, on the alley I have a signature, forgot that wasn't on here. It's a 97 GTS. I'm having trouble getting the 3" clamps on the parts of the piping where they are supposed to go. The 2.5" clamps went on no problem.
viperdude118
Poplar Grove, IL
Since the head of the O2 sensor is striped anyway, I'd just unplug it and replace it with a new one. leave the old one in the old exhaust and forget it.
C
Chipster
Fredericksburg, VA
Yeah, thats what I ended up doing. Now my problem is that I can't get the 3" clamps on to the pipes. The 2.5" ones slid right on no problem. The other clamps are bigger than the 2.5's but I think they must have given me the wrong clamps. Just waiting to hear back from Corsa now, unless any of you other guys with the Corsa know what I'm missing?
C
Chipster
Fredericksburg, VA
I guess I could try there. I went to Pepboys and they didn't have the same kinda clamps. I'm worried that if I used a different kind of clamp, I might have leaks
Racer Robbie
Guilford, CT-USA
Chipster,
One should never use an open end or box wrench on an O2 Sensor. Any parts store can order you a 3/8" drive deep socket that is made for removing and reinstalling O2 Sensors. The socket has a 1/4" slot down the side of it so the wires can fit in the socket and it has a hex on top so you can use a wrench or a ratchet on it.
Hope this helps,
