BlueGTS
I did some logging yesterday with my dual wide bands and what I found was a little surprising. I have a 10psi pulley and WM injection.
The first log the car and SCer were very cool, 180 degrees and I had not gotten into boost prior to the pull. The AF showed ~ 11.6 from 3500-5500. I then drove for a few miles and pulled over to review the log file. I sat with the car off for ~5 minutes so the charger had some time to heat soak from being under the closed hood and not having the fans running. I then made a second log with the heat soaked SCer and the engine temp at ~200. That AF from that log showed ~ 11.0 from 3500-5500. I know that heat will cause the ECU to add fuel but I did not expect this much of a change on the same day within 20 minutes of each other. My question is, how much rwhp do you think I am loosing at 11.0 versus being at 11.5 or even 12.0?
