Seat Removal...............
Don Hiltz
Rainbow City, Alabama
There has been considerable debris accumulating under my seats and I'd like to remove them to vacuum.
The front nuts look easy, but I can't see how the rear ones can be accessed.
HELP..............
Don
TBarrow
Cypress, Texas
The only other thing to do is unplug the wires for the seatbelt indicator. Then just pull them out.
Todd
Nader
New York
My passenger seat is fully functional. As NoRice said, you probably have a lowering kit.
D
Don Hiltz
Assuming you're correct, isn't there another way to access the rear nuts? From underneath?
I did buy it used, so it's quite possible that the previosu ownner lowered the seats.
Thanks....
TedK
Southern CA
If that is the case, push seatback full forward and squeeze an open-end 15mm wrench under the rear of the seat and slowly undo the nuts. It takes more time than you would think just to get two nuts off.
Viper X
I have lowered both seats in my SRT. You can access the rear nuts by putting the seat back fully forward and using a long extension with a socket. 15mm is correct, I think. You'll want a 3/8 inch drive socket - which is smaller in diameter than a 1/2 inch socket - to access the two nuts. Not too difficult but it can be a bit time consuming compared with the OE set up.
bigmike32172
Phoenix AZ
you always could do what a friend of mine did accidentally once.
he was trying to throw a 1/4 stick of dynamite out the window while he was driving during the 4th of july and his hand hit window which in turn made the 1/4 stick fall under the seat. needless to say he hit the brakes and bailed out of the car safely, but man what a cool white flash that went off inside his car, and viola, the seat was ready to take out!
the other cool thing was that he ended up with extra room under the seat from the floor pan being bowled out under the seat!
KERS-VPR
thats a good one. LMAO
xeng yang
